S2 ABY Engine
  • mathias
    • Apr 2012
    • 45
    Originally posted by mathias
    ok i have been checking som grounding, like those on the inlet manifold. will do a thoroughly check of the grounding, ignition and engine speed sensor.
    now ive managed to get the car to work almost, i have come to the conclusion that when you but the throttle to the floor the engine cuts and when you lift off just a little bit it works again, but the dieing on idle is still there but much less are gonna test with original sparkcoils
    • mathias
      • Apr 2012
      • 45
      Originally posted by prj
      ECU restarts because there is a problem with software, there is a bad ground/ignition, or there is no signal from the engine speed sensor.
      These are the only three possible reasons.
      here is a movie https://vimeo.com/43006565
      at 01.50 it almost dies on idle and at the end it dies on throttle, you can hear the ecu restart.
