I've not driven the RS2 for over 5 weeks... before the sympathy comes I spend a good chunk of that time in Florida
...anyway my brother (not Sonic) borrowed the RS2 and had great fun terrorising people up in the midlands, until the car started misbehaving. Issues are:
For 1-2min on cold idle you have to give it some revs or it just dies. After a minute or so it's fine, and won't reoccur until the car is cold.
There's hesitation and misfiring between 3-4k only when it comes on song with WOT. However if drive it with mid throttle, or if you mash the throttle to the floor. However if you progressively apply throttle to WOT it boosts fine.
After hesitation it sometimes goes into limp mode.
I've asked my bro to check clips and plugs around the ISV and along the intake, because the hesitation and occasional limp screamed 'boost leak' to me. He says it all feels tight. The idle is wierd in that it's only that early start of warm-up, like when the lambda is heating up... I changed the ISV the night before I left to solve my 'creeping revs' issue on lift-off.
Anyone got any pointers I can check when I get up to see the car? I'm going prepped to find a major boost leak but the idle is wierd - lots of 'bad idle when hot' threads but not the other way round, it's really throwing me off...
