10w50 Fuuly Synth - Best Oil for fast RS2 450hp Driving
  • UUUdirs2newcastle
    • Apr 2008
    • 655
    I am about to do an oil change ready for the summer and also a trip to the Nurburgring.
    Is the 10w50 the best stuff?
    I have been using 5w30 for a while now.
    My car has a MTM Hybrid KKK Turbo, MTM Turbo Pipework, Larger Intercooler, MTM Remap, Full Manifold inc Downpipe 3" De-Cat Bespoke AAS Exhaust System etc etc.
    Thoughts anyone?
  • Lloyd
    • Apr 2006
    • 1559
    It depends on what oil temperatures you see with your usage.
    10w-50 is recommended by Oilman for on track use with oil temps around 130 and even up to 150. Best to change your oil shortly after spending much time at higher temps.
    ie: when you get back home from your ring trip or other track day.
    RS2+ (now sold...)
    • s2driveruk
      • 12696
      would give some additional protection over 10w-40 and is not anywhere near as thick as the 10w-60 so should be good. what hot temps/idle oil pressures are you seeing currently. I used 10w-60 on a 180k+ miles homefired car and the hot idle was bang on 2bar and temps never north of 130, even round the ring in the summer...
      1992 3b S2 Coupe
        If your not seeing excessive temps dont change, if you fo then 10w50 silkolene is ideal
        • UUUdirs2newcastle
          • Apr 2008
          • 655
          Is the Sikolene a Motorbike engine oil? Where do I get it?
            excuse my spelling, from here http://www.opieoils.co.uk/p-1145-sil...e-engines.aspx
            I've used this stuff for 6 years now
            It's been renamed Fuchs Titan it seems http://www.opieoils.co.uk/p-68898-fu...ngine-oil.aspx
