Audi S2 3B, no electric current to the spark plugs
  • bartolomeus
    • Jan 2009
    • 1475
    • Country: Romania
    I'm having a problem with my S2 and my mechanic cannot find the problem.
    He was doing some basic maintenance to the car and all of the suden when trying to start the car, the car wouldn't start.
    He checked several things and after that he checked if the spark plugs receives electric current and that was the problem. The spark plugs doesn't spark.
    He checked the distributor and the distributor gear was damaged.
    I've ordered it from a guy in Lithuania, it came yesterday. The mechanic put the fixed distributor back in the car and the car still doesn't receive electric current to the spark plugs.
    What could be the problem?
    At this time I've located a 3B MOTRONIC ECU here in Romania and I've talked with that guy to send it to me, maybe that's the problem.
    Any advices would be highly appreciated.
  • vr6peter
    • Dec 2003
    • 223
    • Country: Austria
    Hi.
    I think the distriburor is not in correct position.
    I had the same problem when I changed my cambelt.
    Try to turn the distributor so the OT and ignition module must be in correct position.
    If this is not correct you may have this problem.
    Peter
    • bartolomeus
      • Jan 2009
      • 1475
      • Country: Romania
      Hi Peter,
      The mechanic already did that. Still no current to the spark plugs.
      Thanks
      • vr6peter
        • Dec 2003
        • 223
        • Country: Austria
        The correct position is alreay a few mm.
        Does the injectors get power?
        • marius555
          • Apr 2012
          • 126
          • Country: Romania
          Salut
          Ai verificat si carcasa ? Daca este crapata / sparta te vei lovii de aceeasi problema . Daca te ajuta , am o "punga " cu componente de la starter'ul meu . Din 3 am facut unul functional . Daca te ajuta , da'mi te rog un pm .
          Numai bine .
          • prj
            • Mar 2010
            • 6308
            Pull the codes from ECU.
            Your distributor is in incorrect position, or there is no signal from the hall sensor/crankshaft position sensor/engine speed sensor.
            Although engine speed sensor fault ALWAYS shows when car is not started, even when it's ok.
            • bartolomeus
              • Jan 2009
              • 1475
              • Country: Romania
              Yesterday I've received a brand new distributor. I've mounted the new distributor on the car today and it started just fine.
              The distributor was the problem...
