does anyone know what pressure turbosmart vee port will hold on the standard spring before it starts to open the valve??
turbosmart bov
Tags: None
You mean with out counter pressure?
With counter pressure it will hold what ever your throw at it, as the piston has the same pressure each side.
With out the counter pressure it will depend on what you turn the top cap too as that adjusts the spring tension..
Either way they are stiffer then the oem valves..
I have one for sale if you want?91 S2 coupé - RIP
98 S8 - Luxury barge -
ok.bo i think i bought this from you 2 years ago..will it be ok for over 2bar?with vac line attachedComment
thats the ones...will it be ok with 1???
is the weld on the right side end to stop the hose coming off???
mine just blew off the turbo end!!!!Comment
Yes, i put some slugs round the ends to stop the hoses popping off.
If your hose ever pops off and your running the maf in stock location just unplug it, otherwise the car wont start because it wont be sucking air past the maf.
I had to do this a few times.
It should work fine with one valve, i only used two because i had a pair left.
It will just stay open a fraction longer to dump all the air.
Its worth lubricating the piston on the veeport every so often. I just used silicon spary lube..91 S2 coupé - RIP
98 S8 - Luxury bargeComment
nice one!!
