What sort of power will this turbo support with a built motor Wagner manifolds 750cc injectors ect ect .
Will it do 600bhp as it's advertised ? Or are they blowing smoke ?
The COMPRESSOR RACING Comp-R RS35
SPECIAL LIMITED TIME OFFER- JUST £450!
600bhp capable*Holset HX35 based turbocharger, ideal for tuned engines from*1.6 to 5 litres in capacity, and 5litre+ in twin turbo form- THE best value performance turbocharger on the market.
After a limited test runs in 2011 and earlier this year surpassed all expectations and sold out before we knew it, we're back with a new*batch of our Compressor Racing RS35 turbochargers (now jokingly named the TurBONE as they have been so reliable compared to the equivalent unit from Garrett, the GT35).
Specification-
Compressor housing- 4inch ported shroud*inlet*(MWE- Map Width Enhancment*ports) and 2.5in outlet
Compressor wheel- 8 blade HX35 with 56mm inducer and huge 78mm exducer
Centre section- Big shaft and oil cooled centre section (traditional T3/T4 Garrett inlet/outlet fittings)
Turbine wheel- HX35 70mm inducer, 60mm exducer
Turbine housing- 12cm divided (TwinScroll/SplitPulse) non-wastegated housing with T3 inlet flange and 2.5in V-Band outlet flange
All turbos are 100% brand new and come complete with gaskets
We're sure you know the fantastic performance of Holset HX35 turbochargers, and a simple Google search will tell you all about them*if you are not.
As you can see from the pics the quality of these units is exceptional, and the price is*LESS than HALF what you would pay for the equivalent unit from a more 'famous' (but often*overpriced and underperforming)*brand.
Unlike most units which are pushed to the limit when used on a tuned road car, HX35s run at around 30psi boost for many hundreds of thousands of miles on their OEM applications, so are very understressed when used on a tuned road car, hence their huge reliability, popularity, and why we based our RS35 on these units, using almost totally OEM parts.
For more information or to ask us anything before you purchase,*please ask or visit www.compressorracing.com
Grab a bargain!
Specification-
Grab a bargain!
