Ouch, cam damage?
  • Rikki Kitto
    • Feb 2010
    • 6276
    Ouch, cam damage?
    This is after my oil pressure failure, opinions please
  • mcandmar
    • Apr 2004
    • 5118
    Hard to tell from the pics but the wear looks pretty normal to me.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • s2_bo
      • Oct 2005
      • 6067
      Doesnt look to bad to me. Was it run for long with out oil pressure? should polish out anyhow by the looks of it.
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • Rikki Kitto
        • Feb 2010
        • 6276
        The engine actually nipped up so more damage to the crank I think, still started after for a few seconds but obviously shut it down straight away.
          JP is your man for this kind of thing. As above, it looks ok to me untrained eye
          • willg54
            • Jun 2009
            • 2055
            id say that looks normal too
            1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
            1994 Audi 80 - 2.0 8v (slow but reliable!)
            • JP
              • 1858
              The lobes look like normal wear and tear with no hot spots. However this is not the area that gets damaged when it runs dry. It is always the cam journal and camcaps that take the punishment, so until they are removed from the head you can't tell.
              You can however depending on the level of damage repolish and re use.
              One thing you definately want to do is remove the plastic splash shield these get brittle with age, break up and block the oil pick up pipe.
              UrS6 Stroker + HTA3586 =
              • andy10v
                • 5996
                Pull the caps and look for scoring/galling/heat colouration.
                And bin it or replace? Is it needed?
                Sold ABY-stock
                • 8690q
                  • Aug 2009
                  • 103
                  Cam damage ? That's nothing, this is cam damage
                  • andy10v
                    • 5996
                    Nothing a good bit of weld will not fix
                    Sold ABY-stock
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      I like an answer to that one as well if you catch this thread JP?
                      I do know the 3B splash guard is stronger than the ABY item as I picked up a second hand ABY splash guard that I 'was' going to use over the the exhaust cam under the extra breather I've added to the front of the cam cover. However upon inspection I binned the ABY one as it was riddled with hair line cracks and about to start disintegrating. My old 3B one looks fine and is made of thicker plastic.
                      Think I'll price up a couple of new 3B one's to be on the safe side, I want one under the breather to stop excessive amounts of oil passing into the system.
                      1990 B3 2.0 80 quattro.
                      1992 C4 2.8 Avant quattro
                      1994 MTM RS2.
                      1998 B5 TDI quattro Sport.
                      2000 B5 TQS.
                      • mcandmar
                        • Apr 2004
                        • 5118
                        On an ABY i say bin it, makes filling with oil a real pain in the ****. Also seen them disintegrate as they get old and brittle.
                        My 7A never had one and the only down side i can see is a slow oil seep from the cap. If you remove it when running the cams spit oil out all over the place.
                        • andy10v
                          • 5996
                          I have to say I found that really annoying!
                          Sold ABY-stock
                          • JP
                            • 1858
                            Bin them and run a fresh oil filler cap to stop leakage. It's only there to stop oil splashing out the oil filler cap when the engine is running it serves no other function. And in all honesty anyone that thinks they feel the need to remove the oil filler cap of a running engine deserves to get splashed with oil.
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              Great advice, one less thing to replace too cheers JP
