Ouch, cam damage?
  • Pat D
    • Dec 2011
    • 748
    • Country: Australia
    Originally posted by JP
    Bin them and run a fresh oil filler cap to stop leakage. It's only there to stop oil splashing out the oil filler cap when the engine is running it serves no other function. And in all honesty anyone that thinks they feel the need to remove the oil filler cap of a running engine deserves to get splashed with oil.
    I remember holding my finger over the cam lobe through the filler hole on idle with the old 10v, just to see what it felt like. Things you do when you're 17 with your first Audi
    ABY S2 stroker (work in progress)
    B5 1.8T quattro
    B4 2.3 (decommissioned)
    • K Simmonds
      • Dec 2007
      • 7627
      Bet it didn't feel too good!!!
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • GazzaG60
        • 4133
        ive had a cam snap under the 4th cam cap between the 2 lobes for pot 4 if we count from the frontof teh car. it ran but like poo.
        a clean snap it was holding open ex valves fro cyl 5 and half of 4.
        no engine damage somehow. maybe skimming the pistons helped me here. that was a 7a ex cam on mine.
        • andy10v
          • 5996
          Did you find any reason why it had snapped?
          Sold ABY-stock
          • 8690q
            • Aug 2009
            • 103
            Gazza,
            Was there no bolts missing from the cam caps, no snapped cap holding studs or anything ?
            New camshaft in and away you went ?
            • Cobra
              • Apr 2009
              • 78
              • Country: Portugal
              #21
              Can somebody give me a scheme of the sequence and position, of the parts that hold down the camshafts!?
              They are numbered from one to ten!
              Maybe a dumb question, but need the help!!!
              *95' Clio Williams
              *94' 19 16valve
              *94' S2 Avant
              • Rikki Kitto
                • Feb 2010
                • 6276
                hope this helps
                  Originally posted by Cobra
                  Can somebody give me a scheme of the sequence and position, of the parts that hold down the camshafts!? They are numbered from one to ten! Maybe a dumb question, but need the help!!!
                  Make sure that you read the numbers upright from the intake side of the engine and that you don't swap 6 and 9.
