^^^^^ as above first number cold start viscosity 2nd number hot viscosity.
2nd point carplan = death sentence to performance / turbo engine. The oil can't take high temperatures of the turbo properly and breaks down into watery pi55 causing a drop in oil pressure. Run the platinum stuff from the main dealer much better suited to turbo use.
Now when you are checking oil pressure it is checked at 2000rpm. If it exceeds 2bar at this point there is no issue. If it is below 2bar you need to use a mechanical gauge and verify. The figure at idle will fluctuate depending what tomorrow the engine is idling at and how hot the temperature is. With air cooled oil coolers the oil is automatically going to get hotter in warmer weather. Subsequently lower oil pressure.
As a PRJ mentioned the pressure is a measure of resistance. In a performance engine ease of flow to a certain degree is better than high pressure as you want the oil to pass over the bearings quickly to take the heat away from them. Thicker oil will not cool the rotating assembly as quick and is more susceptible to cavitation at low oil temps.
W40 = 100c continuous 110-115 peak
w50 = 110c continuous 120-125 peak
etc....
Hth
etc....
Hth
