Replace rods on my UrS4..
  • Carfreak
    • Apr 2012
    • 225
    Hi!
    I´m thinking of replacing my stock rods with Scat ones from 034 and just wounder what parts I need to do this job ?
    I will remove the head with the in/ex manifolds bolted on including the turbo so no new gaskets there..
    is it a good idea to replace the chain for the cams and the lifters ?
    When reassembly the sump, should I go with the oem gasket or silicone liquid gasket ?
    Do i need to change the piston rings or hone the cyl if the compression is good on all and not consuming oil ?
    Should I go for the dropping head gasket or go with the steel one with stock thickness ?
    My goal is 500whp when I´m done with stock pistons!
    Hope u can give me some tips and recommendations!
    I allready have an fully rebuilt engine waiting but I will probably sell that one and go with the cheaper alternative on the engine allready in the car
  • caterpillar
    • 2480
    Originally posted by Carfreak
    Hi!
    is it a good idea to replace the chain for the cams and the lifters ? ok
    When reassembly the sump, should I go with the oem gasket or silicone liquid gasket ? NO liquid silicone l
    Do i need to change the piston rings or hone the cyl if the compression is good on all and not consuming oil ? if you have over 300000km om the clock
    Should I go for the dropping head gasket or go with the steel one with stock thickness ? mls gasget ; nice
    you need bigger injecktors; may new 040 pump; bigger turbo,and full remap..
    here you go
    • Carfreak
      • Apr 2012
      • 225
      Originally posted by caterpillar
      here you go
      Thnx m8!
      I allready have 044 pump, gt35r, 630cc injectors and so on
      The only ackilles heel are the rods
      • prj
        • Mar 2010
        • 6308
        You won't make 500whp on pump fuel with stock head, even on 8.0:1 CR. And you will need a very thick gasket to get to 8.0 CR.
        You will need octane booster in fuel, meth injection or similar.
        With ported head, possible larger valves you can get close. If you plan to use the full range on that turbo, you should use 7A cams and probably get mechanical lifters...
        • Carfreak
          • Apr 2012
          • 225
          Thnx for the info
          Right now I´m running 98 octane fuel, what´s the possible horsepower from a stock head with 7A cams that I allready have, forgot to mention them (I´m running hall in disty)
          So i will probably make around 500 engine horsepower with my setup ? My goal is 500whp..
          My horsepower gain could I get with ethanol (E85) that is a common pump fuel here in sweden ? I know that I need atleast 3 044 pumps for that goal..
          • caterpillar
            • 2480
            have a topic at savarturbo.se... / linktips
            • prj
              • Mar 2010
              • 6308
              Yes, on E85 easily.
              • Carfreak
                • Apr 2012
                • 225
                Tusen takk, skall titta!
                Yes, on E85 easily.
                okey well see how it goes
                In 2-3 weeks I´ll order vems pnp ecu and start tuning so the emissions is okey for mot, after that I will change the rods and some other stuff such as an adjustable fpr and fuel press guage!
                • prj
                  • Mar 2010
                  • 6308
                  Stay away from adjustable FPR's. Use the standard 4 bar FPR.
                  • Carfreak
                    • Apr 2012
                    • 225
                    Thnx for the advice, i´ll do as u say!
                    Right now I´m crossing my finger and hope that my tax money will be recieved about the 7-8th of June.. Around $4000 to spend on the car
                    That money should be enough for a rod replace, new ecu including tuning
                      I take it that you solved your misfire at idle problem? You never gave us a conclusion on quattroworld.
                      • Carfreak
                        • Apr 2012
                        • 225
                        I´m going with prj´s answer on that: bad tuning causing this and very much true indeed since I´ve got some info that the car the parts are from had a different setup of cams that he sold before I bought the stuff - he claimed he was using 7A cams that I have but turned out to not be true at all!
                        Even have my thought that some of my rods is bent using 1,7bar with this bad tuning. Well see what we got when the sump comes down
                        Did get a really nice price on part from CP-Service here in Sweden that I can´t resist
                        just have a little question, what serpentine belt should I use when I don´t have the ac pump mounted ?
                        A quick movie on my car and the upgrades: http://www.youtube.com/watch?v=crx1pvOSWXE&feature=plcp
                        A questions, if I will be replacing the pistons rings, should do a slight honing ? is it okey to do this If I seel upp the bottom of the cylinder so the dust can´t reach the crank and so on ??
                        I´ve read in some volvo manual that if u wan´t to change rings without honing u´ll change em all except for the top ring - true or false ?
                        Anyway, I will inspect the cyl bores for scratshes, blank areas and such, if everything is okey I will reuse the stock pistons and rings, if not, the engine will come out and be sent to a shop for bore and hone with deckplate and new JE pistons will be fitted!
                        Does anyone know were to find the wrist pins for the stock pistons or is it a included part in the rod kits ?
                        • Carfreak
                          • Apr 2012
                          • 225
                          Here come a complete list of everything needed except for the Oil and Oil filter..
                          1 x Crank Pulley Cog, Audi I5 "Super Torque"
                          1 x Connecting Rod Set, Scat, Forged 144mm I5
                          1 x Cam Gear, Autotech, Audi I5 20v or VW 16v and 058 1.8t
                          1 x ARP Head Studs, Audi I5 20-valve
                          1 x Timing Belt Kit, 2.2t, AAN/ABY/ADU
                          1 x Multi-layer Steel Headgasket 10v/20v hyd.
                          1 x Rod Bearing Set, Coated, Audi I5 10v/20v
                          1 x Valve Cover Gasket, Audi I5 20-valve
                          1 x Oil Pan Gasket, Audi I5
                          1 x Timing Chain 1992 Audi S4 Q Turbo Iwis
                          1 x Camshaft Seal 1992 Audi S4 Q Turbo Elring
                          1 x Crankshaft Seal 1992 Audi S4 Q Turbo Victor Reinz
                          20 x Hydraulic Lifter, "lightweight" VW/Audi Version
                          1 x Fuel Pressure Regulator, Drop In, 4bar
                          1 x Fuel Pressure Gauge Adapter, Audi AAN, etc
                          1 x Bottom End Gasket Set 1992 Audi S4 Q Turbo Victor Reinz
                          I think I´ve covered it all, comments ??
                            ...just have a little question, what serpentine belt should I use when I don´t have the av pump mounted ?
                            if "av" = air conditioning in English, then Yes..the 1293 mm one shown in this diagram:
                            • Carfreak
                              • Apr 2012
                              • 225
                              Thnx!
