I am looking to replace the bearing of the visco axle that is in the alu support that is also support for the ac compresor.
The problem is that i do not find an oe nr for this because this version of axle/bearing is not bolted(3 bolts) on the alu support.It is presed into alu support.The bearing seems 2 pcs and it is about 70mm/40mm.I do not see any clip holding bearing on its axle and i am afraid i will have to get the whole unit.
Please help!!
It is AAN
Please help!!
It is AAN
