Engine Build - AAN / ABY/ RS2 20vt - Questions?
  • lcsmith
    • Jul 2007
    • 477
    Hi guys,
    That's me gathered up all the parts I need for my AAN / ABY / RS2 20vt conversion, I'm putting the engine in an Audi 80Q (Type 89) - thread - http://www.s2forum.com/forum/showthread.php?t=52258
    Since the engine is out I’m going to get the components all cleaned up and painted and rebuild everything, while it’s easy to get around it I thought I might as well change the timing belt and do the cylinder head gasket…….so……..
    So on the garage floor I have;
    AAN engine
    ABY Wiring Loom
    ABY Water Rail
    ABY Fuel Rail
    ABY PCV System
    ABY Cam Cover
    ABY Boost Pipe
    Audi 90 Instrument Cluster
    Audi 90 Flywheel
    Audi 90 Radiator, Plumbing, Brackets, etc
    Audi 90 Sachs Performance Clutch kit with reinforced pressure plate and organic clutch
    RS2 Remapped ECU - Hoffer
    RS2 Injectors - Hoffer
    RS2 Hybrid Turbo - Hoffer
    RS2 Exhaust Manifold
    RS2 Inlet Manifold
    RS2 Intercooler
    Porsche 996 Front Calipers (425/426)
    314mm Audi Discs
    OEM Boost gauge and “turbo” vent blank – Ebay.de
    I'm looking to get;
    044 Fuel Pump
    Metal Head Gasket & Head Bolts
    Thermostat & Seal
    Exhaust Manifold Gasket – Do I need an RS2 exhaust manifold gasket or are they the same?
    Inlet Manifold Gasket – Do I need an RS2 inlet manifold gasket or are they the same?
    Turbo to EM Gasket – Which gasket do I order?
    Turbo to Down Pipe Gasket – Which gasket do I order?
    Turbo to EM bolts
    Turbo to Down Pipe bolts
    Wastegate Gaskets – I’m using the AAN wastegate, I read that there is no such thing as a wastegate gasket, can anyone confirm this?
    Cam Cover Gasket Kit – Do I need an ABY cam cover gasket kit?
    Samco Hoses.....?
    Bambridge Brackets
    Porsche brake pads to fit those calipers
    Hoffer reckons that it should be around 350-370bhp, do you have any other recommendations / advice, or do you think that everything else is strong enough to reliably cope with the upgrades?
    Leigh
    Audi A4 (B7) 2.0 Tdi (140PS)
    Audi 80 (Typ 89) Quattro 16v
    2 x Audi URS4 2.2 20v Turbo
    Audi 100 (C3) Quattro 2.2 10v Turbo
    Audi 100 (C3) 2.2 10v Turbo (Auto)
    Audi 200 (C3) 2.1 10v Turbo - Scrapped
    2 x Audi 80 (Typ 89) Quattro 1.8 8v - Scrapped
  • Rikki Kitto
    • Feb 2010
    • 6276
    Great looking start to your project, defo no waste gate gasket got mine off at the minute and it's just a metal ring that sits in between.
    • djh
      • Jun 2011
      • 1622
      I'm looking to get;
      044 Fuel Pump - drifting jo had a good link for them
      Metal Head Gasket & Head Bolts - get a head set from gsf NOT pete reeve as they are cheaper than him.
      Thermostat & Seal - tps/gsf
      Exhaust Manifold Gasket – Do I need an RS2 exhaust manifold gasket or are they the same? - it will be in the head set
      Inlet Manifold Gasket – Do I need an RS2 inlet manifold gasket or are they the same? - in same kit as above
      Turbo to EM Gasket – Which gasket do I order? - stock one should do
      Turbo to Down Pipe Gasket – Which gasket do I order? - stock one should do
      Turbo to EM bolts - ebay are cheap for these
      Turbo to Down Pipe bolts - same as above
      Wastegate Gaskets – I’m using the AAN wastegate, I read that there is no such thing as a wastegate gasket, can anyone confirm this? - don't remember seeing one.
      Cam Cover Gasket Kit – Do I need an ABY cam cover gasket kit? - in the gsf kit
      Samco Hoses.....? - get roose, they will turn up quicker
      Bambridge Brackets - brilliant stuff from him
      - check out le audi s2's group buys.
      A victor reinz kit will get you the majority of bits you are after, they are around £70 from gsf.
      • lcsmith
        • Jul 2007
        • 477
        Thanks djh! Answered all my questions
        I'll get ordering tomorrow, had a quick look on gsf but the head gasket set is out of stock, I'll give them a call though to double check, if they don't have any then I'll call quattro corner.
        The Roose hoses look good, I think I'll maybe have to buy them as I go along, they're a bit more expensive than I thought
        I found driftin jo's link but the link doesn't work.....
        • djh
          • Jun 2011
          • 1622
          quattro corner will be around 50 quidmore from the price he was selling them on here.
          • lcsmith
            • Jul 2007
            • 477
            Can you buy stuff from him through the forum?
            • Tonks4x4
              • Nov 2005
              • 3062
              Get a set of rods.....
              Audi Nut!!!
              • lcsmith
                • Jul 2007
                • 477
                Which rods and where from?
                Right guys next question - which rods and where from?
                  Aromatic2 for rods
                  • SE_30
                    • Apr 2010
                    • 1114
                    • Home: England Current: Israel
                    I'd include a oil & water pump while it's out... then you could do the mains, big ends, thrust..... ohhh where do you end.
                    Stuart
                    B2 90 quattro with boost
                    • lcsmith
                      • Jul 2007
                      • 477
                      Originally posted by Jamo
                      Aromatic2 for rods
                      aronmatic2 doesn't have any until the end of the summer he reckons, any other suggestions for rods?
                      I've got the water pump already, the oil pump I will price up.
                      Thanks for the input
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        Personally I'd just check the condition of your existing oil pump, new oil pumps are very costly and there have been some issues regarding their quality. You need to check the lash between the gears with a feeler gauge, can't remember the figure off the top of my head.
                        1990 B3 2.0 80 quattro.
                        1992 C4 2.8 Avant quattro
                        1994 MTM RS2.
                        1998 B5 TDI quattro Sport.
                        2000 B5 TQS.
                        • JP
                          • 1858
                          Integrated engineering with the force fed wrist pin oiling. More expensive option but that way you retain the original pressurised oil feed to the small end bush providing it with longevity when running big boost figures.
                          UrS6 Stroker + HTA3586 =
                          • Costash
                            • 878
                            • Home: Romania Current: United Kingdom
                            English please m8
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              Pretty sure JP is talking about Connecting rods
                              1994 MTM RS2.
                              2000 B5 TQS.
