First DIY job and I f$%k it up
  • karlblues2
    • Jul 2004
    • 402
    • Home: England Current: Australia
    I took the rocker cover off last week for jet hot coating and put it all back together yesterday. Very pleased with myself. Reconnected battery, and she started first time A load of mechanics were stood around me saying what a good job for a non-mechanic, when oil started pouring out all over the workshop floor. I turned the engine off and managed to find what was wrong........I'd not replaced the half circle rubber grommett / blanking plate at the front of the rocker cover. It was hidden from view behind the timing belt cover. That's my excuse and I'm sticking to it So I basically have had it towed to my local VW/Audi garage to replace the timing belt as I haven't got the tools or the know-how or the money to stuff that up So I went home last night, closed all the windows, and turned on the gas Oh well, I'll keep trying
    Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
    Audi 90 Quattro 20V 1989 7A
    Audi TTRS 2010 APR stage 2 +
    Triumph 675 Street Triple R
  • s2driveruk
    • 12696
    hang in there mate, i used to be the same, repair the broken item and cause two other things immediately next to it to break LOL
    David
    1992 3b S2 Coupe
    • 91_S2
      • 612
      Happens to everybody one way or another. I forgot to use blue Loctite on 3 bolts when doing my timing belts - the 3 bolts that protrude into the oil galley.
      The main thing is not to give up. It is too much fun wrenching on our cars. I have gotten to the point where I change stuff that is not broken just to have an excuse to bruise some knuckles
        Dont give up mate!
        Use this website from future reference: http://www.s2-audi.co.uk/technical.htm
        I search the forum web or ask on here before performing jobs, theres a load of mechs who aree helpfull
        • Pete_RS2
          • 800
          Oh joy - Just what I want to hear before I attempt mine tomorrow.
          So what is that grommet ? Is it the half moon shaped plugs which come with the gasket set - I thought these were both at the back of the head though ?
          Now RS2'less
          '99 VW Passat VR5 Sport
            Pete me and my mate did it in an hour using http://www.s2-audi.co.uk/tech_articl...ver_gasket.htm
            Main thing to watch out for there is two places that the gromment can go in at the back, make sure you put it in the outer one! and the other one goes at the front behind cam cover.
            • Pete_RS2
              • 800
              So it is one of the half moons from the gasket set, right ?
              Now RS2'less
                Doh , It's too early in the morning, Oops my mistake heres a pic
                http://www.vagparts.com/s2/D3/23.jpg and http://www.vagparts.com/s2/D3/20.jpg
                Another guide from VAG Parts: http://www.vagparts.com/s2/D3/rad3.htm
                  Can you see where i mean on the right theres 2 holes for the half moon's and it needs to go in the outer one to make a complete seal?
                  • Pete_RS2
                    • 800
                    Gotcha. Thanks for the link Jamo
                    Karl must be talking about a different grommet/blanking plug though as his was at the front of the head
                    Can you see it in this pic Karl ?
                    Now RS2'less
                    • karlblues2
                      • Jul 2004
                      • 402
                      Thanks guys
                      I'm confused as to what is supposed to fill the half moon hole behind the timing belt cover at the front of the engine as the links only seem to refer to the ones at the rear (which I did) I can't really see it from the photo Pete_RS2 either mate.
                      Any other views possible ?
                      • Pete_RS2
                        • 800
                        Anybody got a close up of this front seal ?
                        Now RS2'less
                        • Mark Halligan
                          • 2001
                          The front half moon seal is actually part of/integral with the black rubber main gasket the only seperate half moons are on the back (bulkhead) end of the head and are usually whitish in colour.
                          Mark - Modded
                          • karlblues2
                            • Jul 2004
                            • 402
                            Ahhh
                            Which probably means that I pinched the gasket on the way back on. Crystal clear now that I am an idiot. Thanks guys. I'll have a look.
                            • Pete_RS2
                              • 800
                              I changed mine today. Took about an hour & a half. I was extra careful locating the front 'half moon' area.
                              Now RS2'less
