Water Injection
  • Rusty
    • 18953
    Water Injection
    What kits do people use? I'm thinking it might be a rather nice addition to my RS2 setup and want to know costs etc. as I'm looking at exhaust mods and might take a different route depending on budget required for H2O injection...
    Ta
    depends how fancy you want it. Can pay anwhere from £140 to £700 coolingmist is the cheapest / value for money. Aquamist and Devils own are highend. You have AEM as well
    • Rusty
      • 18953
      Cheers. I'm looking at it as an addition rather than something to rely on, so I think something towards the more cost effective end will more than suffice but just wanted to see what is available. I remember looking some which used the MAF voltage instead of a simple pressure switch, so was interested what people use.
        A devilsown progressive kit would do you fine or Aquamist HFS-3
        I want a Aquamist HFS-4 ( replaces the HFS-5 ) but they are mucho money!
        • Rusty
          • 18953
          Cheers, I'll look those kits up
            *cough* audisrs are sponsored by devilsown get it cheaper via them
            • Rusty
              • 18953
              Cheers for the heads up.
              • JP
                • 1858
                Just don't add meth to the waternix tends to wear the intake guides incredibly fast.
                UrS6 Stroker + HTA3586 =
                • Rusty
                  • 18953
                  Cheers, will more than likely use the windscreen washer tank, so it'll have a nit if screen wash in there but minimal meth.
                  Devilsown kit looks likeit might be doable with the 30 psi map sensor or 0-5v sensor. Should be a nice thing to have in warmer air and track days.
                  • recall
                    • Jun 2010
                    • 336
                    aquamist,
                    tryed a few kits but aquamist has been the best sofar, what you useing it for??? charge temps or det protection??
                    Boost is what makes the world go round.......!
                    • 20Vcqdriver
                      • 829
                      I use aquamist with the injector controller so that amount injected depends on boost and fuel injector pulse width. Have run a 40% meth mix for 2 years without issue. Remember most only operate at WOT or above a certain boost level so the amount of time weak meth mixture getting added is minimal for road use. Certainly made a difference to mine.
                      1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
                      2004 A4 2.5TDi convertible, re-mapped to 180bhp
                      2011 A5 sportback 3TDi-Backbox delete, remap
                      • Rusty
                        • 18953
                        Purely charge cooling as it's just RS2 spec on a stock engine & clutch.... It'll also mean that it's not the end of the world if it runs out of water and I won't need to get it remapped just yet.
                        • pw-rs2
                          • Oct 2008
                          • 72
                          I spoke to Bruce Morris today and If you are interested in a Devils-Own kit he can do a special price for you if you call him over the Bank Holiday weekend.
                          If you tell him the spec. of your car he can tell the best set-up, jet sizes, progressive or non progressive control etc. He can also offer a fitting sevice at at a very good price if you buy direct from him.
                          His number is: 07851 600826. (just say my name when you call)
                          Robin.
                          • prj
                            • Mar 2010
                            • 6308
                            A devilsown "progressive" controller will dump the same amount in your intake at 3000 rpm as it will at 6000 rpm at the same boost.
                            Because it is based purely on boost, nothing else.
                            Push-to-connect fittings tend to leak after a while.
                            Aquamist is doing it right by using IDC to inject.
                            Personally I will go with a devilsown kit, but with AN lines/fittings, and my own controller which is mappable based on MAF signal.
                            You could get their voltage based controller and run that off the MAF. It will be better than running it off of boost, but if you are running 50/50 and a lot of it, and tuning for it, then it will not be good. But for pure water go for it.
                            Or if you have a standalone that has a free output with a driver and can do PWM based on airflow, that's good as well.
                            Everything else is a half-assed solution IMO. Boost is just pressure. Engines are all about flow.
                            • Rusty
                              • 18953
                              @ pw-rs2, cheers for the heads up on discount but I'm not going to have the funds until I sell my other car.
                              @ prj, cheers for clearing that up, there's little difference in price, so best to go for the MAF voltage item
                              Having spoken to a very 'bad' influence on my car, I've got a few other ideas too
