At £85 are Nissens radiators still something to avoid
  • Colesy
    • Feb 2009
    • 2980
    Have just seen these go onto ebay: Nissens Radiator
    Looks very cheap, considering a behr one is ~£200.
    Too many people seem to have had bad experiences with them though but at this price is it worth getting one as a spare?
  • Rusty
    • 18953
    My Nissens one cracked after 3 years but that's not to say the Behr one is without its downsides. Large core alloy jobbie has got to be the way forwards...
      The Behrs cost about £140 if you ship around, to be fair they last 3x as long!
      AKG is another brand worth considering, they make a lot of the newer Audi OEM stuff
        Hmm http://www.s2forum.com/forum/showthread.php?t=6051 they were crap back in the day and I can't see them being any better now
        I'd be honest if my rad goes pop I'd replace it with a Ali one or 7A one with the aux rad pickup removed
        I need to check thats the right rad
          10v one is minus the aux rad outlet, I've got one fitted
          P/N is 8MK 376 711 271
            10V! there you go, cheers Error I couldn't remember correctly it came from something I was told in 2004!
              For reference
              AKG P/N for S2 replacement is 0085.491.0000
              Behr P/N for S2 replacement is 8MK 376 711 281
                show off good info
                • Colesy
                  • Feb 2009
                  • 2980
                  Looks like £85 isn't much of a bargain for these either, there are other nissens 60442 rads on ebay for £94, didn't realise that that was the going rate.
                  I'll have to stop buying parts from "wesawyoucoming.com" if Behrs can be had for £140!
                  • QuattroFever
                    • May 2006
                    • 1360
                    Had my nissens about 5 years. No probs yet. If any connections leak they can be brazed too. With oem or behr it's a throw away item.
                    The connections are a little soft but as long as you dont go mad tightening stuff up and bending things back and forth they are ok.
                    2p
                    Volcano ABY coupe
                    Ant
                    • andyg plym
                      • Nov 2006
                      • 4646
                      if anyone needs a rad i have 2 for sale also the rad cowling+motors
                      • sidrick
                        • Jan 2011
                        • 1342
                        Had a Nissens rad in my 8v coupe for 2 years without any problems. Also used a couple of their heater matrix' again without issue
                        • TimE-J
                          • Jul 2009
                          • 1292
                          Just thought I'd bring this thread back,
                          @ Error, what make 10v rad did you end up going for? I'm sure you told me at ADI but I can remember and my nissens has sprung a leak!
                          96 S2 aby Coupe. Rebuild Project
                          96 mk3 golf tdi daily.
                            I've got a 10v Behr unit 8MK 376 711 271
                            • darkhorse1210
                              • May 2010
                              • 335
                              Fitted a Nissens main rad to my RS2 and it lasted 15k miles, read into that what you will
