WR fly wheel on AAN
  • goodall
    • Jul 2008
    • 810
    WR fly wheel on AAN
    Just to ask, pretty sure will work, but is the reference pin on a WR flywheel from a Ur quattro in the same place as for an AAN as I'm about to fit said together for my Ur quattro
    Thanks, Stephen
  • Tonks4x4
    • Nov 2005
    • 3062
    Yes that is exactly what you need if you going to retain the original Typ85 gearbox.
    You will also need to purchase a new rear crank spigot bearing to insert into the AAN crank
    Audi Nut!!!
    • goodall
      • Jul 2008
      • 810
      Yep using the original 016 from her
      Need check the part number for the bearing, shouldn't be killer of audi
      On a side note, I notice that the ring on the front the fly wheel could be removed, quick calculation shows be about 2.5 kg and on the outside so removing it would reduce the moment of inertia greatly. And then using a S6 or 7A cover plate, what I have to hand, and the ur clutch disc should work nicely...
