Hello,
I have a problem with received (bought) 3B stock Ecu. Engine starts, car runs, but after hiting boost it gets cut-off. ECU memory give Knock sensor 1 - NO SIGNAL fault. Wiring is checked and OK, both sensors are OK.
Someone told that old (from Audi 200 20V) 3B ECU sometimes have electric problems with internal wiring and NO SIGNAL fault is as result. Does anyone had same or maybe any solution how repair the ECU.
Cheers!
Cheers!
