blue smoke on starting
  • JariP
    • 192
    Try this one : http://urs4.com/technical/repair/tim...ming_belt.html
    It's for urS4's AAN-engine, so it isn't exactly the same thing, but close enough.
    • Doug_RS2
      • 3847
      That comment scares me :eek2:
      • Martynf
        • 1885
        Martyn
        www.vagparts.com
        • Josh-stateside
          • 741
          oh cool another post I can help out with:
          http://www.audi-quattro.org/~cuatrokoop/crank-tool.htm
          Timing belt change is not that bad, but it certainly helps to have some one by who knows what there doing the first time.
          It's a bit easier on the aby motor than the 7a and possibly the 3b(not sure about the 3b). But on the 7a motor you loosen the water pump to get it loose( so basically your letting out coolant) and retighten the water pump once the new belt is back on.
          On the aby motor there is bracket that you do this with. so it's not necessary to mess with the coolant.
          I am running a little late on time.
          But If necessary I can post some pics from bently on this matter.
          Actually I have a great read up on this, I will post when I get back from work( I have some cooking to go do).
          Josh
          • martinjs
            • 3205
            3b is identical to 7a procedure,
            when i realised my head had to come off i thought 'you must be joking theres no way im doing that'
            2 days later had engine in bits all over floor
            remember its only a few nuts n bolts
            • Josh-stateside
              • 741
              Josh
              • Josh-stateside
                • 741
                This is from my aan bently cd. It's the same deal thought
                This is the different part I was talking about vs the 3b motor.
                Bently calls it the Tensioner. Which is basically the bracket the idle pulley is on.
                Aby/AAn:
                Would be a nice upgrade on 3b motors, if not the fact that most people don't swap out timing belts alot.
                • Martynf
                  • 1885
                  That's exactly the ABY set-up. The water pump has no adjustment, it's all done on the tensioner. Nice pic's Josh
                  Martyn
                  www.vagparts.com
                  • Josh-stateside
                    • 741
                    I sent you an email btw martyn
                    Just to let you know.
                    Hoses etc...
                    Josh
                    • Josh-stateside
                      • 741
                      The motor would of went in tomorrow btw, but I was sent the wrong Pilot bearing for the flywheel.
                      Fudge ( the josh leonti version of F*$k)
                      • Josh-stateside
                        • 741
                        Also martyn no need to get back to me this weekend, I forget it's saturday
                        • Martynf
                          • 1885
                          NO Worries Josh!! I saw a mail in from you, I think it's about number 50 ish of a few ;-)) I read the hose response, will let you know soon. Gotta have a little time out of work time to work on my baby you know....
                          Spent this morning working on my bike getting her ready for the MOT (test) failed on one stupid technicality took her back for a re-test and completely fooked my rear tyre on the way back to the bike shop
                          Hope you get the bearing sorted out...
                          Martyn
                          www.vagparts.com
                          • Sweeper
                            • 1317
                            • Country: Latvia
                            #28
                            BTW. I bought the same bently manual for AAN. Dunno why but I guess they don't have a CD for 3b/aby engines.
                            Vadim.
                            New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
                            • audiman
                              • 4827
                              Bently are american and they never had the s2 over there. So no point in making book.
                              My 3b tensioning setup is not like that AAN. You have to turn the water pump after slackening the bolts. All the old 5 pots were like that, inc. diesels. AFAIK
                              Tom C - www.rcmr.co.uk
                              Audi UR Quattro
                              Audi 100 C3 2.0 5 cyl 115ps
                              Audi B5 RS4 645ps 911nm
