For 6 months or so now, when I turn the engine over it will run for a few seconds and then cut out, regardless of engine temperature. More often than not, it will keep running after starting it for the second time. On occasion however, it has insisted on being started three times before it will keep running.
Last week, I ran the tank right down to empty and then filled it with 100 octane fuel prior to a day at the track (which I didn't end up going on). I would usually fill it with 95 or 98. I haven't had any issues starting the car whatsoever since filling it with race fuel
Could this simply be coincidental? Or perhaps an indicator of what is going on? I've had a hunt around on the forum, but couldn't see anything specific to this problem. Perhaps I should just keep using race gas :mischeif:
Any advice would be much appreciated
