I'm a bit confused on which Engine Mounts are required for the RS2. The parts catalog implies that they are the same as those from the Coupe Quattro. The mounts that are in the car now have the same part numbers as the CQ so I ordered a set of Meyle mounts for the CQ. (In Canada you can't order RS2 specific parts locally).
I removed the existing mount and noticed it was not lining up properly with the bolt holes and I believe this may have contributed to them failing. I see on 034 motorsports site that theY reference an offset engine mount for S2's and RS2's which leads me to believe these cars require different mounts.
Can anyone confirm this for me? The part numbers for the mounts that are currently on the car are
443 199 379 D and
443 199 379 E.
443 199 379 D and
443 199 379 E.
