I tryed to start it yesterday it fires up then cuts straight off, if i start it and keep the revs up its fine, but if i try to start it plainly of the key it wont start.
Any ideas im all ,
btw ive havnt got vagcom
cheers in advance
Have a look at your idle stabilisation valve, check it has not come unplugged failing that remove a hose and check that the spindle inside is free, they do get sticky.
N71 Idle Speed Stabilization Valve (ISV or ISS Valve) Info
Originally posted by nip
I tryed to start it yesterday it fires up then cuts straight off, if i start it and keep the revs up its fine, but if i try to start it plainly of the key it wont start. Any ideas?
Sorry I missed this post yesterday. If I had I would have suggested that almost all idling problems are due to a dirty or disconnected N71 Idle Speed Stabilization Valve (ISV) and then I would have sent you to investigate this by clicking on the N71 ISV label in this diagram (all the other labels are hot links as well). Glad you found and cured your problem.
