Hy! I know somebody here said once that in Italy....was sold an 2 litter version of the AAN engine...Is this right?
Iff yes...can you tell me what engine code has that?
Thank You!
All the best!
Eugen
There was a member with a 2 liter AAN engine from Hohenester. Built for the Italian market since they had crazy tax for cars abone 2 liter (as in Greece).
Italian urS4 and urS6 have the same 2226ccm AAN as any other.
OK, I'll modify that.
Italian urS4 and urS6 from Audi have the same 2226ccm AAN as any other. ABT did a special 1993ccm version for Italy based on the NM crankshaft and the AAN block for tax reasons. Live and learn
I´m not sure but if i remember well is AANM engine code. NM block but turbo.
Nuno: I think it was me that made up "AANM" (AAN block with NM crank). Both Alessio (the owner of the ABT 2L UrS6 avant) and I tried to get more details out of ABT but they claimed that they didn't have those records. SO no proof of the NM crank but it makes sense since it was an off-the-shelf item for the Italian market version of the 7A, the NM.
Hello, I'm the member with S6 C4 ABT, I had post in the other 3D all the characteristics of the engine if I remember right.
Alessio
Here is some info from the GenteMotori Feb. 96 article about the Italian market ABT UrS6 (not crank is 77.6 mm throw and compression ratio is down to 8.8:1)
