Idler Wheel Bracket Broken - RS2 ADU
  • steverrquattro
    • Oct 2006
    • 787
    Whilst stripping/rebuilding this engine I noticed that a part of the bracket for the idler wheel is missing. This might sound rhetorical, but should I be worried and replace it?
    What purpose did the missing part serve?
    Steve
    1990 RR 20V
    1982 SWB UR - RS2 Engine
  • Nuvo
    • Nov 2003
    • 3825
    It's a hex nut shaped casting that has sheared off. The belt tension is adjusted using this.
    I can't understand why it would be broken though as it should never need a lot of torque applied to it.
    • quattrostyle
      • Oct 2006
      • 6229
      probably the 3 small bolts were still tight when someone tried to adjust it?
        There's a fair bit of corrision in that pic, probably corroded and someone tried to move the tensioner without undoing the holding bolts 1st and whoooooops!
        • prj
          • Mar 2010
          • 6308
          Just weld on a new nut, problem solved.
          • steverrquattro
            • Oct 2006
            • 787
            How can the bit that's snapped off adjust the belt tension? Has anyone got a pic. of how it should look?
            Steve
            1990 RR 20V
            • spink
              • 4382
              you put a socket on it and turn it
                It's a nut, you put a spanner on it to move the tensior up and down to adjust cambelt flex
                • re2500
                  • May 2007
                  • 2185
                  If you look at the bracket, of the three bolts holding it on, two are slotted. so you loosen the three bolts and when you turn the hex (broken) the whole bracket will pivot around the bottom of the three bolts thus tightening or loosening the belt!
                  "Difficult is worth doing"
                  • steverrquattro
                    • Oct 2006
                    • 787
                    I understand now......simple.
                    I've always adjusted the belt tension via the waterpump, but then again that's on a UR.
                    Anyone got one of these parts to sell?
                    Steve
                    1990 RR 20V
                      I know you have it figured now but here is a photo (from Fred M. on my home forum) that clearly shows how it is supposed to work. Prj's suggestion of welding a nut on it might work - *IF* you can find an appropriate aluminium alloy nut.
                      • driftin jo
                        • Sep 2007
                        • 2222
                        Drill a hole through it, put a bolt through and two nuts locked together on the bolt.
                        If there is no space behind it for a bolt head countersink the hole from the back and
                        use a countersink cap head.
                        Alternatively drill and tap a hole through it then you don't need a bolt head on the back side at all.
