UrS4 - ground cables!!
  • Carfreak
    • Apr 2012
    • 225
    Hi everyone! Just wounder were all the ground cables are located on UrS4 ? I´ve found the starter ground, intake and valve cover cables.. shouldn´t it be a cable from the engine mount to the chassi ?
    I also found a loose 1m cables hangning from the driver side, near the firewall - could that be a ground cable ? It´s a black isolated cable, kinda thick..
    Keep Calm and Carry ON!!!!!!
    Originally posted by Carfreak
    Hi everyone! Just wounder were all the ground cables are located on UrS4 ? I´ve found the starter ground, intake and valve cover cables.. shouldn´t it be a cable from the engine mount to the chassi ? I also found a loose 1m cables hangning from the driver side, near the firewall - could that be a ground cable ? It´s a black isolated cable, kinda thick..
    The engine ground is located on the exhaust side of the engine and runs from the block to the motor mount. It shows in the photo below as the black cable between the turbo and the exhaust manifold. No idea what the 1m cable at the fire wall is.
    Photo courtesy for Ringbearer on the quattroworld forum.
    • Carfreak
      • Apr 2012
      • 225
      Okey.. thnx for the info!
      I will run 1 wire from chassi to engine and 1 from engine mount to block just to be on the safe side!
