Flywheel torque settings
  • Rikki Kitto
    • Feb 2010
    • 6276
    As title any info please
  • TimE-J
    • Jul 2009
    • 1292
    Auto data says with new bolts 40NM + 180 degrees.
    96 S2 aby Coupe. Rebuild Project
    96 mk3 golf tdi daily.
    • Rikki Kitto
      • Feb 2010
      • 6276
      Cheers, should I have got new bolts? don't think they stretch type
      • Mikes2
        • 1704
        AAN manual is 30 Nm + 90 degree turn
        They're always replace items and come with threadlock.
        Manual also says not to use a click type torque wrench
        Mike
        http://www.s2-audi.co.uk
        • JP
          • 1858
          Interesting have to look into this as always used 60nm+90degrees on the shorter 7A flywheel bolts. AAN ones are longer but same thread pitch so should be same torque setting.
          As for changing them always!
          UrS6 Stroker + HTA3586 =
          • Rikki Kitto
            • Feb 2010
            • 6276
            More expense, but worth it
            • Rikki Kitto
              • Feb 2010
              • 6276
              Anyone know the true settings? Seems a bit hard to do 180 turn after getting them to that torque setting
                This help (same as what MikeS2 said):
                Item 9
                • Rikki Kitto
                  • Feb 2010
                  • 6276
