Cam sprocket is different on a 3B than AAN/ABY. ADU gear is exclusive to ADU engine.
3B and AAN/ABYADU differences - need input
I am told that originally the 3B rods were something like 80 grams heavier than the ADU rod. Here is a photo that supposedly has a 3B rod on the left and an AAN rod on the right. Anybody with old PNs for these?
The rod on the left is definately a 3B rod. Matches the one i have left from my engine before it was slightly deformed
rod 002.jpg91 Modded 3B
14 A6 Avant Black EditionComment
You are right about the head. That whole exercise is useless because the PNs that I picked up are what is available in the system NOW, not back in the day. NOW an AAN head works on a 3B or an RR (or ABY or ADU). But back in the day, the 3B head did not work as a later AAN head because, as you said, the cam position boss would be missing (there are solutions to fix that). Oh well, it only took an hour to do.
Ahh I see, that looks a bit beyond my skill set!
Is this something MRC might be able to hep with or can anyone recommend someone else who's done this before?Comment
Some 3B 200 20vt and S2 Coupe info
3B and AAN similarities and differences
3B Engine Cut-away:
3B Engine With Labels:
3B in 200 20VT Ghosted:
S2 Coupe ghosted:
3B distributor:
Distributor supercedence:
3B and ABT turbo to intake hoses:
3B ECU pin-out:
3B ECU schematic:
3B 200 20vt diagnostic plugs:
3B PCV system:
3B WGFV:
3B and ABY Oil Pressure switches:
3B Fuel Pressure Regulator:
3B MFTS info:
3B and AAN timing belts:
3B Ignition Coil Info:
3B radiator location:
3B coupe exhaust:
OE 3B, AAN, ABY and ADU Exhaust Components: a consolidation of info.
I did say *Some*, i.e. not all.
Anyway, I went to my consolidated exhaust post and posted a 3B exhaust component diagram above.
OE 3B, AAN, ABY and ADU Exhaust Components: a consolidation of info:
are you looking at the ancillaries too like alternator, AC compressor, etcsigpic
1992 3b S2 CoupeComment
(still a work in progress)
I thought the ABY / ADU had slightly higher compression
