Hi everyone! After 3hours of night fun with my car and a slipping clutch I need some advice.
When launching at about 6000rpm I have 0bar of boost
I don´t know if it´s the tune or to little backpressure or to big exhaust housing on my GT35r.
My question is, is it possible to install a launch control on the stock motronic ecu ?
Maybe prj have the answer ?
I also have a another problem, after I have made some wot driving the afr goes down to 18-22 at idle and I have to rev it up a bit to stabilize the afr at 14,7.. could it be a vakuum leak somewere or my fpr that is jamming or something ? Anyone with the same problem ? It seems like it´s fuel related - like it looses fuel press.
I don´t know if it´s the tune or to little backpressure or to big exhaust housing on my GT35r.My question is, is it possible to install a launch control on the stock motronic ecu ?
it works nice but you need a very good clucth , I wasted a stage 4 from South Bend with it only one launch and clutch disk was starting to eat the presure plate.Took a diferent route now, single mass and 707pp from Sachs .
