Does anybody have some timing information for 2005 s60r?
We removed timing belt,marks are clear visible.Need to change camshafts oil seals(belt side ones) and after removing the cap of vtc(volvo write on units,bmw called vanos) i could not hold the camshaft steady to remove inner bolt of variable unit.So took off cam cover( hoping that a key slot will be on camshaft) and found out that variable units have lot of play and they get of the lip of seal and that is why they leak.I got out camshafts and got them fixed and removed the variable units with pulleys.The problem is that units can get in any position on the camshafts and a procedure of fiting should be folwed...
Thx
Do you know the prices for oils in gbox,transfer box,rear dif?
Not to speak about new brake discs and pads...
With the money invested in the car i could buy a perfect b4 tdi
And with the money car was could buy a perfect rs2,3s2,4s4
Thx
