Hi all
Have been having issues with overheating/1st fan speed not kicking in
Have replaced the following;
Coolant Temp Sensor
Thermostat
Expansion bottle+cap
Up until today the fans 2nd speed was kicking in but temps were getting up to 2/3 notches over 90.
My mechanic today changed the thermostat and found leaks on main and aux rad.
He also found that the connector and loom for the main fan had been bodged/repaired.
The original connector seems to be missing and someone has rewired it on with individual spade connectors rather than a proper connector block.
He put everything back together, but said my fan loom/connector is the problem...
Now the fan does not kick in at all, have to currently have air con switched on constantly.
Is the problem with the fan connector or do I need to address something else for example a relay?
Any help would be much appreciated, I dont have a clue what to do.
Coolant Temp Sensor
Thermostat
