Oil leakage driver side..
  • Carfreak
    • Apr 2012
    • 225
    Hi! I have an annoying leakage from the driver side of the engine, somewere under under the second and third cylinder.. Is it a common thing that it leak oil from the oilstick hole if the o-ring is broken or gone ?
    What size is it on that o-ring ?
  • andy10v
    • 5996
    There is an oil pressure sender on the side of the block that can leak, can come through the sender and out at the wires.
    Worth cleaning the area and then seeing where the oil comes from.
    Sold ABY-stock
    • johne
      • Apr 2007
      • 1405
      It is actually the oil pressure switch rather than the oil pressure sender that usually leaks, there's one of each next to each other.
      John
      • Drummer87
        • Oct 2009
        • 1644
        • Home: United Kingdom Current: Scotland
        Pita to do, if you have an aircon rad etc. if you have small hands you might get a 17/19 mm spanner on it. But for a small switch a lot needs to come away to get full pressure on the spanner. Whilst there worth cleaning up that side of block, and check your power steering hose.
          Oil pressure switch and sender info
          Originally posted by Carfreak
          Hi! I have an annoying leakage from the driver side of the engine, somewere under under the second and third cylinder.. Is it a common thing that it leak oil from the oilstick hole if the o-ring is broken or gone?
          It is very likely the oil pressure switch (the white one in the photo below). More details here:
          • vonbeck
            • 2455
            the`re on the passenger side you can do them just, without removing the rad just loosen all the holding blots and take the fan off, its still a pain in the **** did mine earlier this year scrapped knuckle syndrome!!!!!!!!! but do able
            • vonbeck
              • 2455
              sorry noticed your car is LHD so its on the drivers side DOH
                If you say intake side or exhaust side, you don't have to worry about LHD or RHD passenger side orientation issues.
                • Carfreak
                  • Apr 2012
                  • 225
                  The press switch and the bigger one is new.. Lifted my oilstick and saw that the o-ring were gone I´ll try to put a new one there and see if it helps!
