I been getting alot of ideas lately. The motor is going in soon, and I will be running basically a stock Aby setup aside from the clutch setup.
Which for anyone curious:
I have a 4:11 stock 5 speed 7a tranny.
2000+ s4/rs4 clutch disc. ( had to be slightly modified to fit)
200 3b/7a sach sport pressure plate.
7a Single mass flywheel.
However once I get everything running, and once I put some miles on the motor I plan on doing a bunch of upgrades.
First, I am hesitant to drop the motor in because I am thinking of ditching AC. Most of the lines are allready off the car, and truthfully I would only be using it for maybe a 48 hours out of the whole year. I like the fresh air anyways.
So that being said.
I am a little bit worried about the transmission.
I am thinking I will have it tapped for oil lines and add a oil cooler in front of the radiator where the Ac refigerant condensor is now located.
I am also thinking of adding a thin 10 inch electric fan set on "pull" mode to the back of the intercooler. Not sure exactly how I would wire this in, But I have some ideas. Theromostatically controled?? I currently have an aby intercooler, possibly a custom intercooler will be made to match the Aby crossmember later down the road.
How nuts is it to think of adding a custom fan to the intercooler?
I have never seen a setup like so, but for the lack of space would it not be a decent idea? There are a ton of companies that make real nice slim line electric fans.
Turbo setup: something probably in the neighborhood of RS2 spec.
Opinions are appreciated.
Before I jump into anything, I will be doing alot of research to say the least.
I have to admit I am the DIY type person. I get alot of ideas.. Some rediculus, but some make sense.
I will be commenting on this furthure as time goes on.
Josh
So that being said.
Josh
ops:
