ECU fuse location Audi s2
  • mathias
    • Apr 2012
    • 45
    Where are the ECU fuse located on a lhd Audi s2 aby?
    I think they are the No. 27 and 28 fuses under the Motor/Moteur cover (?)
    • mathias
      • Apr 2012
      • 45
      Ok, so there arent any like the s4/s6 has ?
        Sorry I can NOT find the previous post where I *thought* that I had sorted this all out. If it is not one of the MOTOR fuses, it could be one of the fuses in this panel (an S2 or RS2 owner needs to chime in here ):
        • mathias
          • Apr 2012
          • 45
          Under My steering wheel i only have 2 fuse :S and a lot of relays
          • mcandmar
            • Apr 2004
            • 5118
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
              There are issue with the SEARCH function on this website. It took a lot of work to find my previous post about thermo fuses and whether they existed for the S2/RS2 for ignition/ECU reasons. (The answer was NO, and Fuse 27 = Motor Fuse = ECU power):
