A lot smoke in the next turn on the engine
  • M_GORDON
    • Oct 2008
    • 1295
    • Home: Isle of Man Current: Vatican City State
    Hello to everyone
    Just pass some months and I gone here already.
    I have a serius problem with my car, really two problems.
    One is the smoke. If I run seriusly with the car, the next time I turn on the engine, the exhaust pipe blow off a lot of smoke, makeing a fog land on my garage.
    In the past I install some oil tanks but all the they were smollest or bads. And why that I put the PCV system "like" original. Only the N80 is out of the sistem because the pressure valve behind it all the time was "pop off"ing
    It´s possible that smoke was the oil fitted for the hard driving?
    I'm thinking about the PCV system and maybe the Rusty's system.
    PS. the engine is maded from 65k kms and turbo has around 30l kms
    photobucket SUCKS
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    i was using the Coupe with stock engine and stock breather system...and as you says,..after serious hard driving stop the car and then the next morning whem tried to start the engine i made a smoked fog from the exhaust yeah¡¡
    it is normal
    • M_GORDON
      • Oct 2008
      • 1295
      It's normal?
      2 weeks ago I gone to the party with my old friends and the laughs sounds around 5kms
      photobucket SUCKS
      • Rusty
        • 18953
        Does it use much oil or water?
        There are a number of ways that oil can get into the engine, you can easily diagnose the breather by blocking off the inlet hose and small hose that goes to the underside of the IM and then simply running that to a tank for a quick run and then see if it still does it. If it still has lots of smoke then you're looking at the turbo or the engine internals (valve guide seals being worn, a damaged stem seal, piston ring damaged etc. etc.). Engine can be diagnosed using a compression test.
        The other thing to do is to clean out all of the inlet pipework, as it will have oil residue in there, including the IC and then see if it gets filled up again quickly.
        • M_GORDON
          • Oct 2008
          • 1295
          In the past I have an oil catch tank and the car dosen't create smoke. But the tank goes to Full very fast. It´s normal? Or my car or my PVC system are wrong?
          I changed my PCV valve too because the original goes out.
          photobucket SUCKS
          • M_GORDON
            • Oct 2008
            • 1295
            photobucket SUCKS
            • prj
              • Mar 2010
              • 6308
              It's not normal. If you are pushing oil through the breather, either the small valve behind the manifold has failed or your piston rings are worn.
              • mcandmar
                • Apr 2004
                • 5118
                I have the same issue on mine, 99% sure its the turbo seals as it really depends on how hot it was when shut down. With normal city driving there is nothing visible from inside the car, but if drive hard using full throttle before its shutdown i am guaranteed a puff of blue smoke on startup.
                91CQ20v - Gone to a new home
                93UR-S4 - The Magic Carpet
                94S2Bus - The Emerald Express
                • popdemonic
                  • Dec 2007
                  • 1304
                  • Country: Thailand
                  The thing to define between the turbo or engine is smoking is when you first start the car in the morning.once the engine fired up,if the smoke is suddenly out then it'd be the engine is burning the oil.If the engine fired up for 30sec and so on,the smoke is gradually coming out.your turbo seals are shot.
                  The point is the turbo needs times to rising up the temperature before start burning up the oil.I have some kinda problems but i think i found the culprit on my car.I have the Big Mann Hummel catch/separator can and drained motor oil backto sump.Unfortunately,it did not fix the burning oil problem.I did the compression test on 5pots.the result was fairly good(160-165 all pots).I decided to remove the camshafts for a valvestem seals job.All of them
                  didn't look too bad for its age.once i tried to move(from west-east) valves tips.I found there was a lot of play on them,I think my valve guides are poorly worn since when driving the car under boost there's a huge boost leak coming out breather system (the Mann Hummel catch can).I noticed this when my car was on Dyno.
                  one of a few I5 from Asia.
                  • bazburn
                    • Feb 2010
                    • 583
                    Similar prob on mine recently and it was Turbo end play altho it still boosted fine. Would always show up after some spirited driving....
                    • M_GORDON
                      • Oct 2008
                      • 1295
                      YES!!!
                      And I opened my car and changed all the pieces, valves, pistons rims... around 60k kms
                      photobucket SUCKS
                      • M_GORDON
                        • Oct 2008
                        • 1295
                        Yes, is like you say.
                        Initially a lot of smoke like fog and gradually stop.
                        My valve guides are changed too.
                        Where I can buy that MANN oil catch tank? And how much?
                        PD: Thanks
                        photobucket SUCKS
                        • popdemonic
                          • Dec 2007
                          • 1304
                          • Country: Thailand
                          You doesn't need to get the Mann Hummel catch can since it's a bit pricey.
                          You may try to search "catch can" on this forum.there are ton of threads
                          talking about the homemade catch can.i believe you can build one.Try to
                          contact Marc at efiexpress or 034.i got a decent from somewhere but couldn't
                          remember that.
                          • M_GORDON
                            • Oct 2008
                            • 1295
                            remember that.
                            photobucket SUCKS
                            • sailaz
                              • Oct 2009
                              • 647
                              • Country: United Nations
                              I do have this problem with completely new build engine... I mean everything is new besides block, crankshaft and head; all the rest changeable parts were changed with new ones.
                              And smoke is coming out something like for first half a minute after engine fired up and I keep slightly pushing throttle, very difficult to believe that can be brand new BorgWarner EFR turbo seals
