I have the pleasure of replacing a cracked pintle cap on an RS2 injector. Have searched and there appears to be quite a few variants. Its difficult to get an accurate measurement from a cracked one but as far as I can tell it has the following dims:
2.0mm ID nozzle exit straight.
7.5mm ID cap at the top, 7.80mm at the bottom. There is a ridge inside.
It's brown in colour!
The ABY/AAN one is quite different. For a start its green and it has a trumpet exit, flaring from @2mm to @3.5mm. Not sure of the ID as I don't want to break that as well!
No doubt Bosch colour coded the various pintle caps to aid identification although I am a bit surprised that the RS2 cap is not identical to the ABY one which presumably is a trumpet shape to allow a different spray pattern from the multihole discharge rather than a pencil flow from a single discharge.
I will have to find a 3B injector but I seem to remember that also having a brown pintle cap.
So can anybody confirm those dimensions and have a UK source of the correct pintle caps.
