Asking this for a friend as i just drove his car and im stumped.. first off no codes yet.. he is getting them pulled soon. soo... car drives fine, just cuts throttle randomly. lift foot and put back down and off ya go. nothing violant or sudden either cutting or applying power again. its almost like some one is pressing the brake and the car cuts power. vauge description but if anyone could help cheers.. funny feeling its a brake light switch fault of wire broke to it. never checked before he left.
mk4 aum golf problem
its fly by wire btw.. and seems to only do it on the slightest of throttle oppenings, but once done the rest of the stroke of the pedal is useless (as if it was plugged out). lift off pedal and back on its good again. weird one !! no eng light. fuel econ same. performance fine when alls good. gonna have another look tommorow.
1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
take some live readings, gently press pedal all the way down and gently let it off (engine off, ign on) look for voltage spike or drop, should be nice and linear, ideally a graph mode on live readings
Sean.1993 URS4 Avant Emerald Green 350+bhp
1991 Ford Sierra Sapphire 4x4 in Magenta
BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
could be TPS if you got access to vcds watch it on measuring blocks 0% at rest and 100% on floor. However an autoscan will tell you whats wrong.Comment
TPS is the pedal itself. I have replaced an number of these on Mk5's where wet has got into wiring.Comment
My son has/had the same problem on his Golf IV GTi (132kw), and there was a "brake switch" error - don't remember the exact code.
He has bought a new switch but hasn't installed it yet , but since then only had the problem once (in 2 weeks), when going over a bump on the road - go figure
yeah he was saying as i drove it it prolly wont do it now, but it did..seems to be a plausable reason but codes or getting a look at switch will confirm. sound guys1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
