150+ hiding hp. 3b engine
  • prj
    • Mar 2010
    • 6308
    If you want to make power, then T3 0.82.
    And red hot manifold is due to insufficient timing or too lean mixture or a combination of both.
    • JariP
      • 192
      Isn't it more likely to be filthy rich than too lean if the manifold is red hot when cruising on low load? And/or very late timing. With motronic if the idle switch is not working it keeps dumping fuel on overrun and it can get the manifold red hot too, is it the same thing with vems?
      Overall with the spoolup problems it sounds more like cam/ignition timing problem.
      • prj
        • Mar 2010
        • 6308
        No. Richer mixture lowers EGT and does not raise it. Engine tuning 101.
        Late timing is a likely culprit.
        Unless of course the car uses a vapor fuel, such as LPG. But I believe it is not.
        • norheim
          • Apr 2009
          • 31
          • Country: Norway
          timing and mixture should be ok.
          I turned over the head today and put it on the bench. filled it up with water
          aand there is many leaky exhaust valves..
          Maybe i found the fault.? or?
          • JariP
            • 192
            It's not that simple. On low load cruise the aim is lambda 1 or bit leaner, right? Going leaner from lambda 1 the heat release starts to go down quite soon lowering the egt's too. And on the other direction rich enough can raise the egt's. Those things will probably not happen on the "good" tune AFR range, but you don't need to go too far off to get there.
            • adam g
              • Feb 2007
              • 445
              I think you found the cause of low compression.
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                #22
                glad to know that you might discover your headache
                • quattro84
                  • Mar 2006
                  • 947
                  Yes, you did.
                  Because the exhaust valves did not seal under combustion, the pressure got lost and the hot gasses escaped making your exhaust temps run high, and because of that energy spillage it was not making the obtainable torque.
                  Same happens with burned exhaust valves.
                  • quattro84
                    • Mar 2006
                    • 947
                    You need vast amounts of energy to vapourize the fuel (it dissipates the combustion chamber heat, put some isopropanol alcohol on your hand and feel it co cold) and there is no source to oxidize the HC's to create temperature until it reaches your oxi cat and that'll melt it / kill the O2 sensor once you heat it.
                    • prj
                      • Mar 2010
                      • 6308
                      Yes, it does. EGT peak is at stoich.
                      And this is completely wrong, but you can see that on the graph that was posted before me.
                      My point is, there is no higher EGT peak than running stoich, so mixture at cruising speed has nothing to do with a red hot manifold. Timing does though.
                      As I said again - unless a vapor fuel is used, EGT keeps doing down until the mixture is so rich it can't burn anymore.
                      More than that - this is also why otto engines with EGT feedback that run on non-vapor fuels use PID controllers for controlling EGT by enriching the mixture until EGT is on target.
                      • JariP
                        • 192
                        Yes, I have to admit that rich side comment went the wrong way, too little sleep time this week. But I'm still saying with bad enough tune you can see adding fuel raise the egt's but it's more about combination of timing and afr, not the afr's alone. For example way too little timing so the egt's are sky high already and add more fuel in there and see what happens. With good tune it most likely never happens, but it may sometimes help to know it can happen when you are trouble shooting or trying to figure out what went wrong. Just saying leaner - always raises egt's, richer - always lowers egt's simplifies things alot and can lead to wrong way sometimes.
                        • prj
                          • Mar 2010
                          • 6308
                          Adding fuel will lower EGT.
                          The EGT will go down.
                          It is 100% correct when you are richer than stoich. If you go leaner than stoich (which most cars don't due to emissions) then yes, EGT will drop off as well.
                          All this goes out of the window when using a vapor fuel such as LPG unless you inject that directly into the cylinder in liquid form.
                          But for gasoline and many other liquid fuels what I have said is correct.
                          • quattro84
                            • Mar 2006
                            • 947
                            And all if this goes out of the window if one uses direct injection in combination with multi pulse events.
                            That makes it possible to extend your heat release with multiple small injection portions to keep the fire burning being inside and outside the cylinder until exhaust valve completely closes or oxigen content is too low. This will make all your AFR readings go bad, and without measuring rest HC's in the gasses & indicated cylinder pressure it is impossible to judge.
                            The plot i posted before showing the relation between AFR & temperature does differ under DI multipulse conditions.
                            Can make some screenshots from work if one is interested
