Just having a nightmare with this head, took it to a local 'reputable' company with 17 years of experience to have it checked for squareness and pressure tested. I asked them to remove the broken studs, 3 were cut off and one snapped in the block.
When i went to pick the block up they said they would load it into the car for me as I was wearing my work clothes and I have a bad shoulder from a bike accident.
They removed 2 of the studs and replaced them with old studs! as well as on the third they have removed it and left a large score in the mating face for the exhaust manifold.
I phoned them up after I got back to check it and they are just saying that the scratch was there when they received it and they had put the studs in. You ca see though where they have tried to go over it with emery cloth to take the sharp edges away.
I asked them to phone me up if there were any problems and about the skimming so I now have no idea how much they have taken off.
They were not a cheap company and with 17 years of engine rebuilding experience you would entrust them to do a good job.
The things I need to know are if the exhaust gasket is going to leak as it is only a thin composite one with very little compression and any tips of what route I can go down when I take it back to them to sort out in the morning.
Sorry for the essay!
