Crank pulley bolt
  • Rikki Kitto
    • Feb 2010
    • 6276
    Crank pulley bolt
    I know the info is on here somewhere just can't find it, Need the part number for the bolt AAN engine don't think I need the washer sure it hasn't got one
    034105229A
    • Rikki Kitto
      • Feb 2010
      • 6276
      cheers fella is it the same for aan aby
      • europeanme
        • Oct 2005
        • 3817
        IIRC it is....not cheap and don't even ask about the washer they use...its costs a small fortune!...and they don't list the part on etka!...
        • Mikes2
          • 1704
          The washer part number is 034 105 193.
          Mike
          http://www.s2-audi.co.uk
          • SteveH
            • 4460
            Is it recommended to replace this bolt when changing the cambelt? I don't remember buying a new bolt the last time I changed the belt.
            91 Modded 3B
            14 A6 Avant Black Edition
            • Mikes2
              • 1704
              I've never replaced it when doing timing belts unless it's damaged
              Mike
              • andyg plym
                • Nov 2006
                • 4646
                i have a spare bolt if needed from my old 3b
                  Yes. And since it is a stretch bolt, it is supposed to be replaced at every timing belt change. Washer is fine to reuse.
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Mine didn't have a washer behind it looks like the bolt has a fixed washer type thing going on
                    • adam g
                      • Feb 2007
                      • 445
                      When I fit one without washer the the belt wandered over the edge of pulley and fouled the back plate, not a good condition. 16 quid for bolt as I recall.
                      • Mikes2
                        • 1704
                        Where did you find the source of info which states this is a stretch bolt.
                        There is no mention in any Audi documentation to replace this bolt.
                        Mike
                        • Drummer87
                          • Oct 2009
                          • 1644
                          • Home: United Kingdom Current: Scotland
                          The bolt now is like 30 quid from Tps. Ive decided to change the centre bolt, camshaft sprocket, camshaft chain, obv timing belt, relay roller. Small fortune for the parts but rather spend money on oem.
                          • SteveH
                            • 4460
                            It may be a stretch bolt that's used well within it's elastic limit. If so, I'd presume it could be reused without any issues.
                            91 Modded 3B
                            • Thuppu
                              • 4115
                              Also Febi does the bolt. Was something like 7 euros last time I bought it.
