Running in dilema
  • 20Vcqdriver
    • 829
    Running in dilema
    OK, what do people do on here regards running in a new block and ensuring a good piston bed in and ring seal.
    Debating whether to have the engine refurbed, ported head etc but run it in on the K24 until run in, as I know the map is accurate and will not wash the bores or have it running lean when using it on boost to seal the rings etc. Or does someone have a chip set that's pretty close for a 3B GT3071 on 440cc Bosch injectors
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
  • Ian Simmonds
    • Jun 2005
    • 2858
    There is various schools of thought, but we went for the, don't wring it's neck approach. So kept it sensible for te first 1000 miles, did a lot of mixed driving so it didn't settle. Then started stretching its legs for next 1000... All is well at the moment, but I suppose only time (a very long time) will tell. About to do its 5th oil change and it's just over 2k old...
    93 MTMS2 Avant
    • 20Vcqdriver
      • 829
      Thats the othwer point, make and brand of 'bedding in' oil to use for the first 200 miles, then what to use after that and what mileage can I start using my Pro-s synthrtic oil again.
      Was told not to be too gentle as rings need to seal in first 500miles or less and need boost pressure to do that properly, any thouights on this theory?
      • Audi_CQ
        • 940
        • Country: Norway
        This has been discussed before if you search for it. This is the other school: http://www.mototuneusa.com/break_in_secrets.htm
        • Sleeper_Avant
          • 2372
          my rule of thumb,
          Road Cars: dont keep revs "low" drive the car as normal, what we are trying to do is not stress the engine, i.e torque
          mineral oil (20/50), under 4000rpm no boost for 200 miles
          whatever OE reccomended oil and filter for next 500 miles, 4000rpm low boost 7psi max
          OE oil and filter again, same conditions 500 miles
          rev up to limmiter if you desire, low boost 500 miles
          now for your desired oil (10W 60 in my case) set car up as it will be used, have fun!
          Motorsport and track/1/4 mile cars
          Engine dyno run in period as per the engine builder
          I have only had 4 engines fail on or just after running in period that did not produce power as they should
          subaru EJ20 x2, idiots abusing them from the turn key
          ST170 260bhp track car, customer did not want HP oil pump, died on dyno at 8600rpm
          YB Cosworth T4, actuator pipe split giving 40+psi, bye bye no.3 piston!
          10+ years with this rule of thumb cant be wrong but everyone has different ways
          1993 URS4 Avant Emerald Green 350+bhp
          1991 Ford Sierra Sapphire 4x4 in Magenta
          BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
          • 20Vcqdriver
            • 829
            Thanks for this, Did a long search but this never came up
            • 20Vcqdriver
              • 829
              Originally posted by Sleeper_Avant
              my rule of thumb,
              Inclined towards this method with perhaps using just mechanical boost, but would you fit all the new parts not knowing if the map is suitable or run the block in on the K24 etc which is known correct map so eliminateing lean or overly rich mixture during running in???
                Not that again
                • 20Vcqdriver
                  • 829
                  Originally posted by Jamo
                  Not that again
                  I can see the theory behind it but putting so much stress on the bearings when using mineral oil would not be good at all, so a compromise is where I'll be going... Engine out in 5 weeks and the fun begins
                  • MrVain
                    • Oct 2008
                    • 189
                    Well after building my engine i might have driven a maximum of 100 miles. Then mapped it and got 603whp. Have driven it hard ever since and that 2 years ago. Im running Kendal 20/50 oil and there is no smoke at all.
                    • Ian Simmonds
                      • Jun 2005
                      • 2858
                      Our engine definitely 'changed' as the mileage increased, it was lightened and balanced by John (JP) and it settled down as the mileage went up.... Having invested a considerable amount of time, money and effort into the car, I'd have been nothing short of a raving lunatic to wind the thing around the limiter on day one... Sleeper's run in approach is very similar to what we did...
                      93 MTMS2 Avant
                      • Audi_CQ
                        • 940
                        • Country: Norway
                        The only parts that needs "running in" is piston rings and cams/lifters. Mineral oil is still oil and old race engines have been run on it for years so bearings will be ok. What destroys bearings is lack of oil pressure and not type of oil.
                        • Sleeper_Avant
                          • 2372
                          provided the engine and sensors were fine before then it should be fine to run the engine in on any injectors provided the map isnt rich as hell
                          if the engine melted a piston or detonated then this needs identified and rectified before you start the new engine
                          dont leave a newly built engine ticking over for prolonged period either, especially if new rotating valvetrain has been fitted
                          theory behind the mineral oil if to help the rings carbon up i belive, worked for me so never questioned it
                          All of the above is IMO ofcourse, im not saying its gospel, just how I have done so
                          • Sleeper_Avant
                            • 2372
                            and the mineral oil is only for the first 200-500 miles!
                            you can buy propper running in oil, but 20/50 is like 1/5 of the price lol
