Excuse the terrible video guys, but does this look right for the dashpot operation?
Revs dropping when lifting off
99% of the time these problems are caused by air leaks.
Adjusting switches, changing sensors etc are usually done to just mask the problem.Comment
also grab a multimeter and measure the resistance (pin 2 and 4 iirc, can someone check pls) of the idle switch in the throttle pot, it should be 0 ohm when closed; mine was ½ohm and that was enough to upset the ecu and not stabalise the idle. after replacing the TP with a new one, idle run is as it should be againComment
G69 / F60 Throttle valve position potentiometer /idle switch information
Looks normal to me.
Here is some Throttle Position Switch/Idle swithc info (including testing):
Which was accessed by clicking on the G69 / F60 Throttle valve position potentiometer /idle switch information label in this diagram (all the labels are hot links for future reference):
