Heatshield flap over right enginemount?
  • Trankelstein
    • May 2008
    • 119
    Hi,
    Installed two new heatshields on the right hand side today and the smaller one has a kind of flap over the enginemount. Is this correct or do i have to bend the flap down towards the enginemount mounting bracket? I think the right traverse can be able to fit under the flap but the old one was so mashed up i can“t see if it was there before..
    80 quattro 1984..... S2 sedan 1994
    Zermatt silver......... Brilliant black
  • andyg plym
    • Nov 2006
    • 4646
    never seen that before,surely it must tuck underneath.
    • stocious
      • Jul 2012
      • 838
      i think it does..
      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
        I had to fold mine up a bit while i fitted the engine, then fold back over once its tightened up
        • Trankelstein
          • May 2008
          • 119
          flap
          ok, so you had that wing covering the enginemount before you folded it aside like in the photo?
            Yeah the heat shield covers over the top of where the engine mount bolts up
            • Trankelstein
              • May 2008
              • 119
              Thanks Greg
              The engine is soon back where it belongs after 3 years of absence, just lacking enginemounts and a few minor fixes like routing the 230V cable through the torpedowall (for the cabinheater)
