Has anyone seen freeze plug for ABY/AAN with an fitting or do i need to weld ? Where is best place to buy An fittings and hose? for the water return from the turbo like this one http://pitstopusa.com/i-5069396-joes...ale-flare.html
I think you are talking about the 035103111B (Item 32 below) "union" which is not threaded. Item 23, the turbo coolant FEED line connects to it via a clamp.
