Snub mount alternative
  • tajgreidotu
    • May 2008
    • 324
    • Country: Spain
    In order to install a front mounted radiator in my 3b , I need to get rid of the stock snub mount.....
    Conserving A/C, what possibilities do I have?
    Thanks guys!
  • tajgreidotu
    • May 2008
    • 324
    • Country: Spain
    rad and crossmember im going to mod
    • mcandmar
      • Apr 2004
      • 5118
      From memory an S4/S6 has the snub mount down low similar to the V6 engines. Might be an easy option to use that snub mount on the engine, then weld a bracket onto the V6 crossmember for it.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • tajgreidotu
        • May 2008
        • 324
        • Country: Spain
        Thanks mcandmar,
        I already thought about that solution, but im not sure if ill be able to keep a/c in place.
        Can i use aan mount and a/c compressor?
        • tajgreidotu
          • May 2008
          • 324
          • Country: Spain
          Is this a snub mount?
          • tajgreidotu
            • May 2008
            • 324
            • Country: Spain
            Im pretty sure AAN snub mount goes in the same position as 3B A/C compressor......
            pffffff
            • mcandmar
              • Apr 2004
              • 5118
              Thats a pity, would have worked perfectly...
