Hi experts
I have an RS2, with new stock turbo, wagner IC and manifold, 3" exhaust (no cat), ported head, adjust. cam gear, Porkkis chip.
Went to a trackday - it ran absolutely fantastic the first 3 hours
Then it suddenly began to cut boost, it goes from 1,6 bar to 0 when the needle hits 5000rpm. Its a permanent fail, but the car runs perfectly at lower rpm until the cut occurs.
VCDS:
2 faults keeps comming back:
00516 - idle contakt (F60)
30-00 no connection or short to +
00515 - Hallgeber (G40)
01-10 signal to + periodic
Have testet N75 valve, and idle regulator with VCDS - they clicks
The hallgeber is almost new
WG has not stuck. Camgear has not moved from the spots.
any ideas ???
VCDS:
any ideas ???
