Hi,
Would appreciate some advise on sorting out my 95 RS2, it is standard apart from K&N air filter, has 210,000 miles. Have been noticing that it is not as lively as before, not giving the shove in the back at 3,500 rpm and no DV sound when lifting of the throttle.
Today I did a boost leak test and that shows there are none, I cleaned the MAF plug and that certainly made it run smoother but still not as I remember.
Downloaded the codes with VAGCOM and this is what was there
00573 - Lambda - 08-10 Control Limit Superceeded - Intermittent
00561 - Mixture Adaptation - 13-10 Adaption Limit (Nul) Not Reached - Intermittent
00561- Mixture Adaptation - 14.00 Adaptation (Add) Exceeded
00519 - Intake Manifold Pressure Sensor(G71) - 17.10 Control Differential Intermittent
When the block readings (group 2) were opened, the Abs Pressure reading was 1061.4mb and not changing, even when the engine was revving up and down, it stayed at 1061.4.
From this we began to suspect a vacume leak, could see no problems in the engine bay but when I got closer to the ECU I could hear a leak. The hose going to the ECU was in place but bent over, but was not leaking. When I removed the ECU I found a black rigid vacume pipe which had come loose from a joint into a flexible hose heading off to the left side. I fixed this and also replaced the hoze to the ECU, so no more leaks. (I think but have not done a test !)
Took the car for a run but still no significant improvement. I also do not hear the flutter of the DV when I change gear...
Can anyone advise on what to check, is there any common faults to watch out for.
Not sure what next to do ??
Thanks
PAUL
Thanks
PAUL
