oil pressure gauge???!!??
  • avnts2
    • Apr 2004
    • 36
    hi there,
    can anyone shed some light on what the heck,should this gauge should read ?????,, using the synta-gold , and change the oil every 6 month or so regardless off mile`s, car is an aby m plate with 86k, ,, problem or what troubles me is the gauge sits around 80ish , regardless when hot or how long/fast you drive it!! , is there possible some sensor needing replaced??
    any pointers would be greatfull,
    cheers ....
  • dan_b
    • Sep 2003
    • 3670
    Which gauge are you actually talking about - the one that says 80-something is the oil temp gauge. If you're cruising on normal roads or pottering around in traffic, 80-90 is a fairly normal oil temperature: in my experience it's only when you start thraping the car for a reasonable period thatyou'll see oil temps increase to >100. If oil temps start exceeding 140, give the engine a breather!
    Your oil pressure gauge should probably sit at about 1.7-2.0 bar when idling when warm. If you're using Synta gold all the time it'll probably be at the low end of this range: if you change to using a thicker oil like Castrol RS 10/60, or the Millers Competiton 10/60, you'll see an increase in idle pressure to around the 2.0 mark.
    • Fat Audi 80
      • 10547
      Great post, absolutely spot on.
      Steve.
      The Perfectionist
      • avnts2
        • Apr 2004
        • 36
        oil temp,
        thanks for that ,soz about gauge confusion,
        sound to me like ,it`s fine, i find that the pressure gauge is giving good
        readings also , the pressure gauge at hot idle sits at a steady 2.bar,
        and when driving/ mostly sits at 5bar motorway drivin so a think all`s well
        cheer`s for help in clearing this matter up..
