G4 crank position and G28 engine speed sender info
Originally posted by bilko0795
Can anyone plse guide me to where the crank sensors are on a 3b engine I believe there is one by the fly wheel? Thanks.
The two sensors bolt to the block, just at the flywheel since they both need to count things on the flywheel (the G4 crank position sensor needs to see the pin and the G28 counts the teeth on the flywheel to determine engine speed)
Here they are on a 3B (reference mark and engine speed sensors):
Here they are on an AAN (same location):
