RS2 No boost after 30seconds of startup
  • prj
    replied
    Check your marks incl. cam timing and cam belt ASAP.
    Possible it has slipped one tooth. You will get the hall sender code then as well.
    If not, then replace G40.
  • RS2ZuidAfrika
    replied
    Originally posted by rynaqui
    The G40?
    i think so too. But to get to that sensor is going to be a job!
    trying to look at all possibilities.
  • rynaqui
    replied
    The G40?
  • RS2ZuidAfrika
    replied
    this was in june
  • simon20vq
    replied
    First thing first the cam marks do not aligen with the block if this is how yours is??
  • A80Avant
    replied
    if you have the( ! ) look for error codes. there should definitely be some
  • RS2ZuidAfrika
    started a topic RS2 No boost after 30seconds of startup
    OK so perhaps i worded this thread incorrectly:
    My RS2 had a boost cutout initially at about 4500rpm, but has developed into a situation where it is virtually normally aspirated all the time- except if i switch off the engine and fire her up again.
    If i pull away immediately after startup, she boosts all the way through in first and second gear, very very strongly! but by third the cluster shows (!) symbol and beeps three times, after which there is no boost for as long as the car is on.
    Please advise.
    Avantus let me know if you had the same symptoms before you sorted your timing to "one tooth left".
    Thanks chaps
