the headgasket going still doesn't explain why your 2nd stage fan doesn't work.
AFAIK the 1st stage should only come on when the AC is switched on or with the after-run pump activated (you can test these functions).
The second stage will kick in at 90deg or thereabouts, the 3rd stage later probably around where yours does, a couple marks above 90deg, at a guess around 105-110 degrees.
The fan normally only runs for around 10 seconds, just enough to satisfy the rad thermo switch, then it will switch off again until the temp rises and so on.
In reality you should rarely see the 3rd stage running in normal driving as the 2nd stage takes care of the bulk of the cooling work - obviously the 3rd stage kicks in when its not enough.
There is a possibility all this hot running has contributed to the HG starting to go. The HG doesn't have anything to do with the 2nd stage fan not kicking in
HTH
HTH
, honestly
it says 'high' not 'low' pressure switch
