I've been chasing down a coolant leak which I found to be at the thermo switch. Car idles a little bit lumpy, pulls well enough though.
I topped up the coolant and ran the engine whith the expansion cap off,
I notice there is a lot white smoke coming from the tailpipe and that the pink coolant has turned murky very quickly.
*****, looks like this loss of coolant has caused my gasket failure. So the moral of the story is if you have a coolant leak fix it immediately.
The car is a 10v NA coupe, I want to replace the gasket myself. I've done a reasonable amount of work on the car to date and I know whats what in the engine bay.
Is this within the reach of a first timer, any helpful advice from the guys that have there heads off on a near weekly basis or anyone else with some previous experience?
Why do these things always happen when the days get shorter and colder?
